Keep gas tank from rusting in storage
Old 10-13-2006, 03:31 AM
maxhasbro's Avatar
maxhasbro
maxhasbro is offline
6th Gear
Default Keep gas tank from rusting in storage
Hello brand new to this site and my first post I have an extra fatboy gas tank that I keep in my family room and I was wondering what is the best way to protect the tank for future use so I don't get rust in it? Any tricks or info is appreciated.
Thanks Garry
Old 10-13-2006, 06:43 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Default RE: Keep gas tank from rusting in storage
Factory tanks have a good liner seal in them to prevent rust. If you don't trust that do the job, just spray a little WD-40 in it.
Old 10-13-2006, 10:07 AM
Keystone's Avatar
Keystone
Keystone is offline
Keep it full of gas.
Old 10-13-2006, 12:26 PM
BigGeorge's Avatar
BigGeorge
BigGeorge is offline
LPS 3 is a spray can type protectant. It sprays on wet but as the propellent evaporates it leaves a thick almost wax like film of lubricant. The can even states its for long term storage to prevent rust formation............................BG
Old 10-13-2006, 12:31 PM
Dancemax's Avatar
Dancemax
Dancemax is offline
a tank full of gas in the living room?..no way
Old 10-13-2006, 12:45 PM
grunt's Avatar
grunt
grunt is offline
Make it a planter
Old 10-13-2006, 12:49 PM
Jezcruzen's Avatar
Jezcruzen
Jezcruzen is offline
Remove the fill cap. Circulating air will prevent the accumulation of moisture.
Old 10-13-2006, 02:43 PM
Draggin S's Avatar
Draggin S
Draggin S is offline
Well,
Keep it full of beer and refill it when empty to keep it in constant use.......let me know when you get it full and I'll be right over.
Regards,
Draggin (what seems to get thirstier on Fridays) S
Old 10-13-2006, 04:40 PM
GTK's Avatar
GTK
GTK is offline
If your really worried about it rusting,pour a quart of kerosene mixed with 1/2 qt oil in the tank and slosh it around and drain out.The oil will coat all the inside surfaces untill you fill it with gasoline.
Old 10-16-2006, 02:12 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
ORIGINAL: Dancemax
Ok, I'll bite. Why do you keep a gas tank that you might use again in your living room?
Quick Reply: Keep gas tank from rusting in storage
