Re-Tuning after installing a Heavy Breather
Old 03-11-2011 | 10:44 AM
FatherNikki's Avatar
FatherNikki
Question Re-Tuning after installing a Heavy Breather
In my winter modes on my RKC I had stage 1 done complete with a performance modual and SE pipes. They did not change the air filter except to remove the back plastic cover. I am thinking of getting a heavy breather part # 29253-08A picture attached. Will I need to get it re-tuned after that is installed? If so can I do it myself or does it take a lot of tech skill? Not my chosen profession but I can learn with the right directions.
Attached Thumbnails Re-Tuning after installing a Heavy Breather-heavy-breather.jpg
Old 03-11-2011 | 12:51 PM
oldairboater's Avatar
oldairboater
I would tune any engine that has decreased back pressure from an exhaust change and increased air flow from a breather improvement. Is it necessary on your engine from the small changes you made?---Probably not. Your engine came from the factory lean. It is now even more lean. Lean is mean but fat last forever. I like a fat engine even in these overpriced gasoline times. This is a common question on this forum and shows up often. You will get lots of opinions. Simple way to check your bike is watch you mpg---check you plugs for color. Listen and feel the bike on acceleration and deceleration.
Old 03-31-2011 | 11:05 AM
FatherNikki
Ok so i put the heavy breather on and now when I am stopped for a red light or such there is a ton of white smoke. Also after letting is sit shut off for a few minutes it was very hesitant to start and it back fired a bit. What did I do wrong and how can i fix it.
Sitting in Phoenix with a broken bike
Old 03-31-2011 | 10:35 PM
SteveO-ll's Avatar
SteveO-ll
Get it Dyno'd.......Be Safe...........It sounds like its to lean now.
Old 03-31-2011 | 10:42 PM
FatherNikki
Found out it was the bolts i used. I had Stage 1 put on and the HB needed the old original bolts to works correctly. Something to do with how they are vented. Put the original breather on till i get the right bolts and it is working fine.
BOSOXFan
08-29-2013 11:56 AM
saenzraf
04-28-2012 12:14 AM
Armstronges
04-05-2012 03:08 PM
ironman_sg
09-21-2009 03:55 PM
Tele00
08-24-2009 05:02 AM
Quick Reply: Re-Tuning after installing a Heavy Breather
