Balancing Rear Wheel
#31
Changing a tire out is a filthy dirty job. No doubt about that. If the OP took the photos right after the job I can see how the tire/rim would look dirty. It just appeared to me to be really, really dirty and the tires looked a bit beat up to me. My apologies to the OP if I spoke to soon. As far as Frogfarmer's comment about riding a filthy dirty bike I will simply say to each his own. Personally I take care of my stuff and it takes care of me. My bikes are not Garage Queens by any means but they do get maintained and well cleaned on a regular basis. Not only is it a safety issue but I would rather ride a clean machine than something that looks like ****. I have seen those bikes where the owner does nothing and just lets them go to hell. Not starting a pissing contest here. If I spoke out of turn or my original comment appeared abrassive, sorry bout that.
#33
Anyway back on track here... I took the bike out yesterday for about 45 min and thought I felt a slight rhythmic vibration in the front, but really was not sure. I thought that maybe it was my mind playing tricks on me since I was Really Looking for something to be wrong. Took the front wheel off this morning and just stuck a big dowel rod through the hub and put it on some jack stands. I know, I know its not perfect but just wanted to get an idea. Anyway, it seemed to be balanced according to my unscientific test. No matter where I placed the tire it stayed put. If I just put a littel pressure on the tire, it would gently roll that direction. A guy on a local forum has a shop and said he would rebalance them for me if I like just to double check, so I may take him up on it just for piece of mind.
Still thinking about Dyna Beads too though. We will see...
Thanks again everyone for all the help...
Phil
#34
No offense taken here... I too like to ride a clean bike, but I do not get crazy about it. Spent about an hour yesterday cleaning the wheels. The first time I had done it since buying the bike last July. Could have probably spent another hour or two just on the spokes, but I think that the wheels look pretty good now. Got the tires all cleaned up too.
Phil
Phil
When I do mine, I can take the balanced wheel/tire and rest a 1/4 ounce weight just a couple inches off center at the top of the tire and the wheel/tire will rotate in that direction.
#35
Hard to get a good read on balance that way because the bearings in the wheel hub typically have too much resistance. You really need 4 precision and low resistance bearings set-up like a v-block to rest the axle into. Then you can get a really accurate read.
Thanks a bunch! I have learned quite a bit this past week.
Phil
