warning about working on forks
When working on ANYTHING that is under pressure, rule #1 is to release the pressure, or lock it down.
I had a friend who was a heavy equipment apprentice and was working on the rear shock from a 125 ton HaulPak (that's a dump truck in a mine) and the cylinder was pressured up with Nitrogen to a few thousand pounds/sq.in. He never let the pressure off and proceeded to remove one of the end caps. Needless to say, he ended up holding his guts in so they wouldn't spill all over the floor, the medi-vac plane arrived and they pumped all the plasma in they could before reaching the hospital over 400 miles away. They were literally pumping the last bag into him as they landed the plane. He barely survived.
So....
So....
![Icon Rtfm](https://www.hdforums.com/forum/images/smilies/icon_rtfm.gif)
Always have an understanding how something works and is put together before you start. It will save you money and possible injury. Telescopic forks have been around since the 1930's (BMW). The technology is not new. Always research your project and you can have the correct parts and tools on hand. It will save a lot of grief. Research will help you decide if you have the skills to tackle the job too.
.....and you should never use a match to check your fuel level.
Manual or not, what did you think was gonna happen when that nut came off?
Received 4,487 Likes
Always cover you fuel tank with a double folded towel when working above the tank. Another one to remember.
