Starter problem
Starter problem
Hello, New thread on ongoing problem.
bike wont start , click and that's it.Checked everything that tells me it is starter. 1997 96" evo
When i rock back and fro , I hear a slight ( how can i explain) engaged sound from the primary. I am worried the starter is engaged and if i push start the bike to get started the starter will stay engaged until it is disconnected from battery , which could be a problem or time issue. Don't know if will cause damage while attempting to disconnect battery.
Can anyone offer help to tell if starter is engaged ?
Cheers
Cheers
Received 4,808 Likes
Disconnect the battery and pull you primary. You'll see immediately if the starter jackshaft gear is engaged on the ring gear attached to the clutch basket.
thanks for replies , thought may be an easier way other than taking off the primary, but probably not.
I have a fully charged battery , keep it on a battery tender ,also it is new.Would jump starting make a differance?
If i bumbed start down a hill and the starter was engaged , would it cause damage?
cheers
cheers
