wierd wear on my front tire please help???
Old 02-14-2011, 11:01 AM
MOTOKILLER's Avatar
MOTOKILLER
MOTOKILLER is offline
Default wierd wear on my front tire please help???
So my front tire keeps going bald just on one side. as ur sitting on my bike, the right side of the front tire is completely bald. the left side is full of tread. this is the 2nd tire this has happened on. i have a 07 softail standard. i can not figure this out please help me out. thx
Old 02-14-2011, 11:10 AM
Hollywood Ball's Avatar
Hollywood Ball
Hollywood Ball is offline
Maybe go left more often? (I had to)
I don't know. Sorry.
Old 02-14-2011, 11:21 AM
bikenut1957's Avatar
bikenut1957
bikenut1957 is offline
Received 2,069 Likes on 701 Posts
Air pressure right? For that to happen it sounds like one fork is longer than the other or the front axle is off canter maybe bad bearings does the wheel wobble if you grab the top while up on a jack. I'm not a wrencher so I could be wrong on both accounts.
Old 02-14-2011, 12:10 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
With not seeing tire, it sounds like a thrust line issue (that's front-end alignment/suspension talk) whereas the scrub-radius (that's tire talk) area (that's the area of tire that is on the ground at any one given point) is being scrubbed to the right causing the wear pattern.
and or
The front wheel is cocked slightly to the left as the front-end (Forks) to handlebar ratio/relation)) is straight, causing the scrubbing effect.
Again without seeing said tire or knowing brand and or mileage it is hard for anybody to figure out (that's common sense talk).
Stop trying to figure out and take it to a professional.
NCTim
06-02-2023 09:48 AM
oldsoldier181
08-08-2018 02:27 PM
NSR
12-11-2017 09:54 PM
trucker7775
07-07-2017 12:39 PM
MOTOKILLER
02-14-2011 11:46 AM
Quick Reply: wierd wear on my front tire please help???
