100 Octane VP Racing Fuel
Old 02-03-2011, 10:55 PM
wideglidebob's Avatar
wideglidebob
wideglidebob is offline
i have run 85 for 5 yrs never knocks runs great, and actually runs pretty cool
Old 02-03-2011, 11:46 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
When OBama gets through adding more Ethanol to our gas it won't even burn so no worries.
Old 02-04-2011, 12:21 AM
Robotech's Avatar
Robotech
Robotech is offline
Originally Posted by carlgrover
My ironhead loves high octane fuel (keep in mind it's 35 years old). When I ran 100LL aviation fuel in it, it was much smoother and ran better. When I shut it down it would stop immediately with no dieseling like a Ford Pinto. There was also no knock.
Which if your IH would knock with the lower octane fuels is exactly why the higher octane stuff made it run so well. The higher the octane, the better it fights knock.
You see it out there in 'berdoo because it is on the way to the river and desert. The guys with boats and off-road vehicles really trick them out and the engines in those vehicles, not needing to worry about smog rules, are tuned for high performance. They run blowers, turbos, and high compression engines with lots of timing all of which will increase an engine's dendency to knock. The 100 octane race fuel will combat that. As others here have said, there is no other benefit to running higher octane fuel if you're not getting knock now with the 91 or less.
Old 02-04-2011, 01:45 PM
streetg7's Avatar
streetg7
streetg7 is offline
bought my bike with 4000 miles on it...mech. asked if I ever used racing fuel....I didnt..previous owner must have...ruined oxy sensors!
Old 02-04-2011, 03:06 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Thats cause he ran leaded race gas instead of unleaded race gas.....
Old 02-04-2011, 04:16 PM
El Rey's Avatar
El Rey
El Rey is offline
Maybe a dixie cup of it added to your fill up will clean out your injectors. Other than that, waste of money.
Old 02-04-2011, 05:02 PM
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
As already stated, it's more of a waste of money for a street motor...There is also an increase in heat during street riding with greater than 100-octane and it can lean the air/fuel mixture out some too!!!
Old 02-04-2011, 05:07 PM
CEJohnson21's Avatar
CEJohnson21
CEJohnson21 is offline
Higher octane is a waste of money unless you need it. Higher octane than necessary does not make the engine run hotter or stronger.
Old 02-04-2011, 05:17 PM
SportsterBob
Drop in 100% Sunoco 110 and blast down the Interstate at 85-mph for 25-miles....Are you FI or carb?
Old 02-04-2011, 06:17 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,988 Likes on 17,898 Posts
Any of the newer twinky bikes don't waste your time . Older high compression shovels or sporties is a whole different ballgame they like higher octane gas , I run 11-1 comp in my shovel a mix at around 96 or 98 oct. wakes the old girl rather nicely .
Quick Reply: 100 Octane VP Racing Fuel
