Favorite throttle assist
Old 01-25-2011, 12:53 PM
sammer4u's Avatar
sammer4u
sammer4u is offline
Originally Posted by Catfish57
Same here cant beat ISO grips with throttle boss.
I too use have the ISO grips with Throttle Boss... Haven't had any issues with it or the grips, very comfortable!
Old 01-25-2011, 01:15 PM
daltrey's Avatar
daltrey
daltrey is offline
I use the Kury ISO's with throttle boss and I hate em. Wish I would have just left the stock grips on but I've already went thru the trouble of putting em on and I'm too lazy to take em back off. Feels like I'm gripping a 4x4.
Old 01-25-2011, 01:37 PM
DeD Fred's Avatar
DeD Fred
DeD Fred is offline
Throttle Meister Dampener
http://throttlemeister.com/
You will never own anything else
Old 01-25-2011, 01:50 PM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,275 Likes on 1,315 Posts
Originally Posted by rjsimmons
I have a set of Kury ISO's with the throttle boss. First off, the grip size on the Kury's are perfect, not so small as to cause my hand to cramp. Second, the throttle boss rests nicely under the outside of my palm so I can keep a constant throttle with little effort. Some I have seen reverse the throttle boss so it sits on the opposite side of the throttle, might give that a try but I like the Kuryakyn.
I like the Kury throttle boss as well. I also have a cruise-mate that locks the throttle so you don't even have to lay your hand on it. That thing is a long trip's best friend but more money.
Old 01-25-2011, 03:38 PM
Hockey Stick's Avatar
Hockey Stick
Hockey Stick is offline
Used a throttle rocker for a few years and it worked well enough. But I now have metal grips which it don't grip onto. I was using a type of plastic band around the grip so the rocker would work but 'course didn't like that.
I'm planning to get a cruise-mate soon.
Useing the stock friction screw was OK, but kind of a hassle. Mine broke so I decided to replace with the cruise-mate.
Old 01-25-2011, 04:28 PM
DMacLeod's Avatar
DMacLeod
DMacLeod is offline
Originally Posted by Beav
Fast...
Dunno 'bout any throttle assist...
Ummm...Errr...could you enlarge that pic ya got by 500%?
Beav
I was thinking the same thing....
Old 01-25-2011, 04:46 PM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
Lot of choices here. Good thread!
Old 01-25-2011, 04:56 PM
t. sawyer's Avatar
t. sawyer
t. sawyer is offline
I have the cramp buster and like it alot. I also have something like the kelver or whatever that thing is called. I only use it when hand is cold or needs a break. Like them both. The little crows foot looking thing just makes it easier to move the thumb screw.
Kroozeabout.
Old 01-25-2011, 05:03 PM
harleydavis's Avatar
harleydavis
harleydavis is offline
I have the same set up and it has made a big difference on long rides!
Old 01-25-2011, 05:36 PM
cptdenny's Avatar
cptdenny
cptdenny is offline
I have 3 different throttle assists on 2 bikes. Cramp Buster on my FXDC which I prefer. Have the Barefoot ******* for the FXDC but in my mind it's in the way, so I took it off.
I have the Throttle Boss with my ISO grips on my Gold Wing but find the TB not wide enough for comfort. The newer ones from Kury are wider and maybe better if I can get them sized for the Wing's over sized heated grips.
Quick Reply: Favorite throttle assist
