Tailbone pain - KICKS MY ASS !!!
AS someone suggested, try Mean City if you want to just get your stock seat modified.
If you want to try a new seat, http://www.ccseats.com/
Talk to Chuck and tell him what your problem is and what you would like.
I have been very satisfied with what they did for me.
You,ll get used to it Not that i don,t put a cushier seat on for long trips but it takes some time in the saddle every spring i go threw a painfull period then in a couple weeks starts to fade away.
You might try rotating your handlebars forward to adjust your riding position a little bit. Moving your hips forward with a little bar adjustment can make a big difference, $0.00. The back rest suggestion is good especially if you also suffer from lower back pain, $400.00.
Backrest & bar adjustment are a big help...you want to be in a good riding position. Also, another vote for Mean City - double memory foam is like sitting on a cloud. They also work the contours so you're not cutting off circulation to lower extremeties...give them a call - much cheaper than new seat.
