Balance front tire Question
Old 01-22-2011, 06:38 PM
piasspj's Avatar
piasspj
piasspj is offline
Originally Posted by Sharknose
Good to know.
fwiw, over the past 15 years or so I have done most of my own tire changes in my garage and as long as I lined the yellow dot up with the valve stem I have never had a need to add/remove/relocate the wheel weights that were place on the wheel, either from the factory or by an earlier tire installer.
Originally Posted by 2black1s
You are either the luckiest person alive... Or your tires are out of balance. I'd bet on the latter.
I check my tires for balance with every change (balancing stand) and usually the weights that are on the wheels have been fine. The couple that I needed to change it wasn't much of a change (same position, just a little more or little less weight).
Old 01-22-2011, 08:19 PM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,797 Likes on 534 Posts
You should have left the rotor on it for balancing. That's probably where your vibration is coming from. It's all part of the same rotating mass on the front of your bike.
Old 01-22-2011, 08:44 PM
JackDupp's Avatar
JackDupp
JackDupp is offline
Good to know.
He's not lucky, I've done the same thing many times. I think it has more to due with top shelf tires. Bargain tires not so much.
Remember..cheap is ...well, cheap.
Old 01-22-2011, 08:57 PM
NickD's Avatar
NickD
NickD is offline
Pretty hard to figure out the original question but it sounds like your dealer correctly did not balance the wheel assembly because they didn't have the brake rotor. If you had keyed the rotor and rim and put them back together in the same position it would have probably been fine. So now you need the wheel assembly balanced. So either bring the entire wheel assembly to the dealer (less expensive at an indie) or build a cheap home balancer.
Here's one I made out of two old jackstands and some $12 skateboard bearings . . .
theojkett
General Topics/Tech Tips
03-20-2021 06:34 AM
Brophywife1968
12-04-2016 08:56 AM
imatkel
03-08-2015 08:52 PM
Forge
06-06-2013 05:47 AM
tcabello
07-01-2012 06:05 PM
Quick Reply: Balance front tire Question
