carb tuning
Old 01-23-2011, 09:28 AM
hatchetman's Avatar
hatchetman
hatchetman is offline
Can you tell me the model number of your carb? any other info would help, pic's of the carb would help!
Hatch.
Old 01-23-2011, 12:06 PM
pleasants9's Avatar
pleasants9
pleasants9 is offline
should i try to set the bowl even lower?
Old 01-23-2011, 12:16 PM
95custmz's Avatar
95custmz
95custmz is offline
Check out www.nightrider.com for some cv carb adjustment tips.
Old 01-23-2011, 12:17 PM
JW1200's Avatar
JW1200
JW1200 is offline
Received 21,404 Likes on 8,422 Posts
Stat over. Step 1: Are you getting a good seal when you put the cv back on the manifold? If it's sucking air, it won't work.
Old 01-23-2011, 12:21 PM
JW1200's Avatar
JW1200
JW1200 is offline
Also there is a lot of info over in the Sporty section of the forum.
Old 02-09-2011, 10:16 AM
pleasants9's Avatar
pleasants9
alright well for those of you wondering i got it all fixed. Since I did everything up here in college i didnt exactly have all the tools I would need. although I cleaned the carb, the ports the best i could, I didn't have any compressed air. well turns out one of the air ports on the face of the carb was badly blocked, probably from that shitty ethanol fuel residue sitting in there while i was rebuilding the engine. One shot of compressed air and all the crap came flying out, put the carb back together, and double checked the float leve, carb tuned up in under 15 minutes now its running brand new!
98fxdwgcmc
EVO
13
07-22-2016 12:34 PM
pacman552sd
Carburetor Related
06-03-2015 10:39 PM
bigdaddy65
Carburetor Related
13
01-12-2010 04:11 PM
bryon857
Ironhead
02-21-2008 06:56 PM
Beeracuda
Exhaust System Topics
13
12-27-2005 03:16 PM
Quick Reply: carb tuning
