Do you spike your fuel??
Old 01-15-2011 | 08:24 PM
mentor70's Avatar
mentor70
Default Do you spike your fuel??
I was having a chat with my Indy the other day and he said he tells the guys with the HOT motors to spike there fuel with C12 or C16 race fuel.
I cant remember what he tells them to mix in, it cant be much, with my 4.9 gal. Dyna i was thinking maybe a quart at the most.
Just wondering if anybody else dose this. and how much do you mix??
I filled up a while back with straight 100 oct. and my bike ran like ***.
i believe that the higher octane required a leaner AF ratio, so i diluted it with 91 as quick as i could and the bike drivablity returned shortly after.
Old 01-15-2011 | 10:53 PM
OldFenderGuy's Avatar
OldFenderGuy
I run good BP 92 octane fuel in my Harley's, and even here in the lower Midwest where temperatures can reach extremes (well over 100 degrees in the summer).
Don't even have a problem running 'un-spiked' 92 octane fuel in my built 95" 2003 WideGlide, which is running a Mikuni HSR 42, JE 10.25 forged pistons, high lift Screamin' Eagle 258 cams and modified heads.
I figure why spend additional money for fuel additives or mixing race fuel if it isn't needed.
Old 01-15-2011 | 10:58 PM
Sigjumper's Avatar
Sigjumper
I have in my Softail, I don't know how much of a difference it really made, but I did it. I started off using the octane boosters and then progressed to adding a gallon of 112 race fuel at about 1/2 gallon per every other tank (I never go below a quarter, so it would have diminishing levels). I gotta be honest, I don't know from a functional level how effective it was, my goal was increased performance not ping resolution. Basically it was purely a method to measure myself w/o use of a ruler... if you catch my drift. Dunno maybe it works, maybe not- I stick to high test 91-93 depending on the gas station and am still quite happy.
Old 01-15-2011 | 11:20 PM
mentor70's Avatar
mentor70
I totally agree, i wish i had better fuel out here in cali.
i have a friend in Arkansas, and he can have quite a bit more engine that i can out here with 91 oct.
Old 01-15-2011 | 11:45 PM
DeJavu's Avatar
DeJavu
I used to run my evo chopper at the drags and find that adding an octaine booster lets a hog put out a little more power. With the long strokes you make use of that slower burn. I don't think there is much difference on the street where most of your time is spent cruizing not running ***** out. I always run 93 over 89 or 91 for the same reason.
Old 01-16-2011 | 12:09 AM
GrimmRider's Avatar
GrimmRider
About every third tank I add a few onces of octane boost to keep things running smoother. Here in California the best we can get at the pump is 91 and even though I only buy Shell or Cheveron fuel its not consistent quality.
Good thread by the way.
Old 01-16-2011 | 03:45 AM
TwiZted Biker's Avatar
TwiZted Biker
I run just under 11-1 on my 93" shovel , while she will run on pump 91 you can tell in the starting and ping knock she does not like it . I'll mix 112 race fuel 1 to 4 when I can and she perks up very nicely . Straight 98 is the **** but @ $6+ a gal ...................................
Old 01-16-2011 | 07:13 AM
kanelakos's Avatar
kanelakos
In my 2010 Heritage owners manual it says:
" Do not use race gas or octane boosters. Use of these fuels will damage the fuel system."
...for whatever its worth....
Old 01-16-2011 | 07:30 AM
HD7585's Avatar
HD7585
Those newer bikes are so delicate
Old 01-16-2011 | 07:48 AM
magna's Avatar
magna
Im always surprised when i read about how low the octane rate is in the states,over in the U.K and i think in the rest of europe its 95 or 97,so i assume the bikes must be tuned differently to take note of that, mind you we sure do pay for it around 8 to 9 bucks a gallon in your money.
Quick Reply: Do you spike your fuel??
