Flash to Pass Garage Door Opener Install
Eastern Performance had them on sale for $56 with free shipping, so based on a few threads regarding the Flash 2 Pass, I bought one. Got it installed tonight, doing the remove the outer-fairing method, verified everything and put it all back together. Except, then it didn't work. Took the outer-fairing back off, unhooking the headlight to set the fairing aside, all worked perfectly. My first thought was that the fairing was somehow interfering with the signal, so I hooked up the headlight but left the fairing down by the fender. Doesn't work; unhook the headlight, it works.
Can anyone tell me what this means? All lights are working properly, including low beam to high beam, but clearly something is haywire, maybe the transmitter isn't getting enough 'juice' when the headlight is powered up. Any suggestions? It's really a cool gizmo, not having to grab a garage door remote, so I'd like to get this sorted out.
I should mention that the wall-mounted switch works properly, opening and closing with the push-button, and that the LED flashes correctly. (The instructions give examples of no LED, or a fast-flashing LED; mine is flashing once every three seconds.)
Thank you,
Thank you,
Thank you,
Thank you,
I admit that I'm more than puzzled. I did not remove the fairing to install mine. I just can't imagine why the fairing would make any difference. All I can think of is maybe the ground (black) wire is getting pinched or???? BTW, the red light on my wall button flashes also. I wish I could be more help and I hope you get it figured out soon. I love mine!!
That's actually as good or better than I'm getting from the HD flash to pass unit. I don't know if your unit uses a piece of wire as the antennae but I found that if I added a section to that I got a bit more range. May be worth a try.
The LED light on the wall switch is supposed to flash every three seconds, which mine does, so that's supposed to indicate that all is normal and working. And from the wall switch, it does.
Thanks for the suggestions,
