Engine braking or hydraulic brakes or both
Jim
I live where life is a little slower, I use gears most of the time, a little help from the brakes. If I chirp the rear tire on downshift, no big deal. I have rode in big cities before, and in those instances, you want to be on your toes at all times. As a matter of fact, I like try to chirp the tire when riding thru downtown in the cities just to freak folks out. I know, that's not cool. But it sounds cool as hell to hear that squeal 2 or 3 times when you come to a light. guess I never grew up!!
Not wanting to nitpic, but unneccesary wear and tear?, what happens when you get on it? In my mind you're putting the same stresses on the motor, maybe less so, cause you don't have the compression stroke exerting strain on the drive components. Any time you slow down do you pull in the clutch and use the brakes to slow you down , or let the motors compression slow your speed? Been riding for too long to agree with the idea that engine braking is bad. my .02. Anyone's who's ever driven a stick shift cage will tell you they downshift to save the brakes.
Received 1,043 Likes
Both here also. I make sure and give just enough blip to get the engine caught up to the rpm's of everything so that the clutch pack isn't treated to harsh catching. My brake pads look almost as thick as they did when new, 27,000 miles ago and the clutch pack isn't showing any wear that I could see either (knock on wood).
Ride Safe All,
Steve R.
PS: Needless to say, I use both, "all" the time!
