rear fender not perfectly aligned? is this how they come stock?
Old 12-09-2010 | 05:39 PM
chuckw2's Avatar
chuckw2
mine is off center a bit to the right. Tire was rubbing with the short shocks on the right side only.
Old 12-09-2010 | 07:12 PM
beatmasterspeech's Avatar
beatmasterspeech
the off center doesn't bother me... the rub makes me a bit weird, it's not major rub but i'll keep an eye on it...maybe take the bolts off each side and see what happens...
Old 03-07-2011 | 08:32 PM
METALKAT's Avatar
METALKAT
Same on my 09RG. I have all the saddlebag hardware off so it's just the fender sitting in the frame. Sitting on a center stand with both wheels off the ground the right side of the fender clearance to the tire is 1" - 1-1/8" gap. On the left side it's 3/8" - 1/2" gap. Maybe when you reattach the bag hardware and exhaust you can do some tweaking to cheat it over but they are definitely coming from the factory that way.
Old 03-07-2011 | 09:32 PM
golfblues's Avatar
golfblues
FWIW, I got mine centered by loosening the fender strut bolts, pulling the fender a bit to the side that has less clearance, & tightening the struts back up. The fender is now perfect.
Old 03-07-2011 | 09:37 PM
shore's Avatar
shore
My 07 is off pretty good. On the good side, it allows me extra room for my 2" drop in the rear.
sharpshooter
04-05-2016 07:38 AM
Rhino-1
EVO
13
12-07-2014 10:30 AM
Ms54Coupe
04-01-2013 11:30 AM
greazy42
Wheels/Tires
05-19-2009 03:38 PM
Hey Zeus
02-28-2006 08:37 PM
Quick Reply: rear fender not perfectly aligned? is this how they come stock?
