Your RESULTS of tire pressure check
Having high-sided my newly purchased gently used Classic in TWO turns before I realized the front tire pressure was 15 pounds and the rear was 12 pounds (she had been jewelry in the PO's garage for three years and I was a Classic dumb-*** not to check the pressure), I signed on to the check it at least weekly crowd. There was a recent thread on how often we check pressure, but interestingly, no commentary on the findings or how often more compressed 79% nitrogen was needed. Also, no mention of whether there was an allowable range before adding .79N.
So...
During riding season, I check the pressure on Sunday afternoon. Generally, I have to pull out the compressor every other Sunday. During this time of the year, here in NC we might have three nice days per month. I check the pressure before each of these, and generally find I'm 2-3 psi down.
I run 40psi in the rear Elite III and 36 in the front. I will allow 2 psi below these numbers for <100 mile journeys due to the absolute PITA of rolling the bike around to find the valve stem, dragging out the 12v compressor, hooking it up, attaching it to the stem and overpumping to allow letdown.
What's your mileage on this matter? Results and do you have a tolerance, or are you OCD obsessed?
Rainy and 58° in Central NC. Good day to ride on the internet.
Final note... last tire installer put a paint dot on the tire where the valve stem resides. Nice touch on a bagger. Really helps. And yes, I do have to lie down to do the back tire.
So...
So...
So...
Some go at the stem, some go opposite the stem, depending on who made the tire.
No need to get over complicated with the tire checks. Leakdown will be different for everyone. Just check them once in a while, and if they are low add some air. A few pounds low will be enough for me to get the hose out.
I'm not in the "weekly checker" crowd but I do check tire pressure at least once or twice a month and always before a big trip. I do it while up on the bike jack for a bath so no problem for me to find the valve stems.
Tire pressure
Need to keep a check. Check mine monthly. Since it cooled off around 45 degrees at night caught my front at 21 lb. (normally 30) Small Deuce front does not take much to be off 10lb. My back was about 31 (normally 36) Can not tell by looking or kicking
if so, that really sucks. but i also can't believe that you took a vehicle that was sitting for 3 years and didn't check the tire pressure. what else didn't you check? you might want to go over that bike with a fine tooth comb....
am i understanding that you wrecked your new bike twice right after you bought it?
With that being said, I usually check tire pressures once a week.
For me I pump em up to max sidewall pressure and have as a result gotten better mileage and wear patterns. Make sure they are check before any big ride and at least weekly. Pressure is the most important aspect for tire safety so I am a little rigorous about it.
R. Todd
I check mine 1X per week, early Sunday before the ride. Last check netted 42 front, 42 rear which is what I run in Metzelers. I have foudn with tubes in my wheels they stay much closer to the pressure I want. I avhe also ridden them with far too little air in them a few times. I check the pressure and ride 2 blocks to the gas station to fill them as opposed to dragging my compressor out to my carport from my apartment. I knwo the people at the gas station so well from adding air that they see me coming and just turn it on for me every time.
Drew
Drew
Drew
Drew
