How do you remove the left handgrip from your bars ?
Also after removing it what glue do you use to put it on your new bars ? Thanks
slid a screwdriver between the grip and bar , sprayed some soapy water in there, wiggle the screwdriver a bit and slid the grip right off , to put the new grips on I tightened the set screws
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Razor blade and blood... long story. My new grips didnt need glue. Also had to sand the old glue off.
I don't use glue on the new bars. Never have had an issue. And each time I change bars I am glad I did not use glue. Getting them off can be a pain. Some say to heat it with a heat gun or hair dryer, some spray wd-40 in between the grip and the bar, and some just leave the old one and buy new ones. I like the grips with set screws too. Easy.
Drew
Drew
I've taken two sets of stock grips off intact in less than 5 minutes. Just worked a stiff wire in and rolled it around the bar.
Since I have no intention of ever reusing them I don't know why I didn't just cut them off. I do have an issue with throwing things away so that may have had something to do with it.![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
The new sets that went on were HD no glue models. The groove inside the left control holds them on.
