internal wiring
Old 11-19-2010, 08:05 AM
TheGeek's Avatar
TheGeek
TheGeek is offline
Good luck getting the pins out of the connectors. Like everyone else, there are no cons.
Old 11-19-2010, 01:04 PM
brenn's Avatar
brenn
brenn is offline
It's hard on the first one, but once you figure it out, it's a breeze. The little screwdrivers that you use on eyeglasses and small electronics are the best tool I have for connectors. After one or 2, you'll be popping them apart in seconds.
Also, the service manual has a lot of info on the connectors and where the wires go and, since you only have to take the connector off one side of the wire, you can always look at the connector that's still on the other part to see where each wire goes back, if you lose track.
Old 11-19-2010, 01:08 PM
QehQeh's Avatar
QehQeh
QehQeh is offline
Originally Posted by Paniolo
...Double check that the holes in the bars are smooth and free of burrs or sharp edges...
VERY IMPORTANT!!!!!
Also, along with shrink tubing (as much as space permits) use some of the OEM type cable wrap (photo below) where the wires exit the bars and enter the neck. You can get it at any good electronics supply store. It's not water proof, so you have to use shrink tube underneath it, but it looks nicer, and adds more protection, than just shrink tube alone.
Old 11-20-2010, 06:05 AM
TheGeek's Avatar
TheGeek
TheGeek is offline
Thanks, I'll try that. I purchased a little pinwheel looking device that was made for the pins, that went flying in the woods somewhere. I never even thought of using a little screw driver, thanks!
Old 11-20-2010, 06:51 AM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
You have better luck with a little screwdriver than a paperclip?
A paperclip is the only tool I've ever seen recommended. They work okay for me but I have run into a few stubborn pins. With those you push the clip straight in till you hear a click and that usually but not always means the pin is released.
Be interested in knowing whether a screwdriver type edge would work better than a blunt edge.
Old 11-20-2010, 07:02 AM
brenn's Avatar
brenn
brenn is offline
Yes, the tiny little screwdriver set I have has some thinner than a paperclip and they are stiffer and have handles to hold. The flat tip head or the allen heads work. Like this:
I got them at Radio Shack, I think.
Old 11-20-2010, 07:58 AM
jimmers1817
I can see where the stiffer steel of the watch screwdrivers w/handles would work better than the soft paperclips. From your previous post I got the impression that you were having better luck using a bladed screwdriver rather than a flat tip. Thanks for clearing that up.
Old 11-20-2010, 04:37 PM
Rockyriver's Avatar
Rockyriver
Rockyriver is offline
Here is the link when I had my stock handlebars, and did mine.
https://www.hdforums.com/forum/softa...den-wires.html
I later changed out the bars and put on a set of Burley Knucklebars.
No cons, just a smooth and custom look when done.
X
Old 11-20-2010, 04:50 PM
Teachinator's Avatar
Teachinator
Teachinator is offline
If you are going with a larger or longer bar than stock make sure that you stagger your soldering joints if you have to add on extra wires for length. If you don't, you'll end up with a hugh knot where all the solder joints are. This would make it harder to make the bends through the bars and the holes in them. Take your time, it's a piece of cake.
PH
Old 11-20-2010, 07:50 PM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,662 Likes on 1,263 Posts
I'm also putting new bars on my bike and need to extend the wires. How do you guys like the Novello extension kits that come 4" 8" and 12" ?
Quick Reply: internal wiring
