Seat wiggles.
Old 09-21-2006, 12:48 PM
tbone52's Avatar
tbone52
tbone52 is offline
Default Seat wiggles.
Does your bike seat wiggle freely back and forth and, if it does, is this normal. I had the Tallboy seat put on and I never noticed until now that the seat freely wiggles left to right or a better description would be it rocks back and forth to each side. Is there some way to tighten this up if it is not supposed to do this? I checked the bolt in the rear on the fender and it is tight. Thanks in advance for the help.
Mike
Old 09-21-2006, 01:56 PM
stafford's Avatar
stafford
stafford is offline
Default RE: Seat wiggles.
take it off and look at it. I'm sure you'll see the problem and be able to fix it pretty easily
Old 09-21-2006, 02:25 PM
KeithB's Avatar
KeithB
KeithB is offline
Big Kahuna HDF Member
the front tab is prolly not under the tank in the pocket where it belongs
Old 09-21-2006, 03:32 PM
Punky Brewster's Avatar
Punky Brewster
Punky Brewster is offline
Yea,take it off & have a look see.This is not normal for sure
Old 09-21-2006, 03:50 PM
oldfartjc's Avatar
oldfartjc
oldfartjc is offline
ORIGINAL: tbone52
Mike
Only your wife or your girlfriends seat should wiggle.
Old 09-21-2006, 04:00 PM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
check the front tab that slips in the frame slot by the tank.
to install: have seat tilted nose down and slip tab into slot, then push forward until rear seat bolt hole lines up. If corectly done and seat still wiggles. Remove seat again and with crescent wrench or adjustable pliers grab the front of the tab and bend sliightly towards the seat pan. reinstall following procedure.
Old 09-21-2006, 09:15 PM
tbone52's Avatar
tbone52
tbone52 is offline
Hey, thanks Sleepneagle and others. I will try to look at that and give a report of what I find. I looked at the seat after removing the rear mounting bolt and it looks like that strap hookup is going to be a bear. I believe I will tackle that tomorrow. Do you all keep those straps on your seats? I can't imagine what they would be good for. How on earth is someone going to have a secure hold on that thing with their hands in such a position so close to their body? I might leave it off unless it is part of what makes the seat more solidly mounted.
Old 09-21-2006, 11:57 PM
Hog_fever's Avatar
Hog_fever
Hog_fever is offline
My seat rocks slightly from side to side. Checked a like model at the dealer, same thing. With only a tab under the tank and a screw in the fender you can expect a little wobble. When sitting on the bike it is very stable. Dont know about your bike, but the strap on my seat is bolted to the fender. To remove seat, remove screw at rear of seat, pull seat backwards and pull out from strap. Hope this helps.
Old 09-22-2006, 12:09 AM
tbone52's Avatar
tbone52
tbone52 is offline
Hog,
I went ahead and removed the rear screw on the seat but the seat (Tallboy) was too wide to slip out of the strap. I think I can lift the seat enough to get an open end wrench on the nut that holds the strap on underneath the seat. The seat is solid when sitting on it but I just didn't know if it was supposed to rock back and forth like that.
Thanks,
Mike
Old 09-22-2006, 12:12 AM
zombie's Avatar
zombie
zombie is offline
Bud's 1200R had the same problem...checked out under the seat and found it cracked. Definitely not normal.
Quick Reply: Seat wiggles.
