Rear tire spins in neutral
That is a huge problem, and it is causing undue wear on your gears, BUT I happen to be in the position to sell you a kit that I have been developing that will totally stop your wheel from spinning with the transmission in neutral. Just send me $3999.95, and I will over night the kit. I prefer cash! ![Icon Mrgreen](https://www.hdforums.com/forum/images/smilies/icon_mrgreen.gif)
If you were using Amsoil....the wheel would be rotating backwards actually taking wear off of your transmission parts and clutch plates. In time, your transmission would be better than new.
![Icon Headbang](https://www.hdforums.com/forum/images/smilies/icon_headbang.gif)
All these guys are WRONG !!!!
It's your master occipulating secondary transducer ...and only I HAVE THE KIT FOR THAT !!!
Obviously you've figured out it's completely normal.... Makes cleaning the rear wheel easier too..(if you're into that kind of thing) ... just be sure not to hit it into gear ...
All Aces
12-07-2010 09:07 PM
