Rear tire spins in neutral
11-08-2010, 06:02 AM
gotta love those smart *** comments
11-08-2010, 06:57 AM
Quote:
Originally Posted by
faber
Or.....warped clutch discs?
no, like others have stated it's in the gears in the trans. oil is dragging. normal.
11-08-2010, 09:54 AM
dope_man_21
That is a huge problem, and it is causing undue wear on your gears, BUT I happen to be in the position to sell you a kit that I have been developing that will totally stop your wheel from spinning with the transmission in neutral. Just send me $3999.95, and I will over night the kit. I prefer cash!
Check's in the mail...
11-08-2010, 09:57 AM
"changing to halogen headlights...."
Where on the wheel should I place the bulb so that the wires won/t get tangled when the wheel spins?
11-08-2010, 10:04 AM
SeniorChief56
To be expected coming from guys named DOPE_MAN and DICKEY!!!!
11-08-2010, 01:05 PM
There are no stupid questions. Only stupid ... Oh wait, that is a stupid question.
11-08-2010, 02:03 PM
The lawn mower reference is wrong.
j1mmy
ever lift the front of your lawn mower and see the wheels turning just from the vibration..the wheel turns just from the trans shafts/gears turning on the bearings agenst each other..nothing to worry about..
11-08-2010, 04:19 PM
The rear wheel is most likely turning due to resistance of the oil in the primary between the clutch plates. Mine does the same thing.
11-09-2010, 01:38 PM
Tail light oil being low can cause that also..
11-09-2010, 02:37 PM
Its the same dynamic principle that made the Smokey Mountain Wimmi-diddle so successful!
