SERT cables
Just talked to the parts guy at my dealer about it. He says you get the block, but usually not the CDs and cables as that is a seperate part number......dunno if that helps
CD and Block come together with SERT Kit.
Cables are not included and I ordered mine from the Harley Dealer.
Different types of cables out there. USB and RS-232 Communication Port (Serial Port), Cable.
My older SERT uses the RS-232 cable to block. Kit Part Number 32108-06.
Contains cable from bike computer to block, and block to PC (Not Mac) computer.
Good question, considering every tuner will have the cables to do the tune. No need to buy any unless you plan on doing some changes yourself and u really need to do your homework before doing that. However, they are handy if you have some decel pop you want to get rid of or want to try a different canned map for a change you made to the motor.
No, I do not plan on tuning it myself. Never had a SERT always Power Commanders so I did not know they did not come with cables. Bike seems to run real good. The only thing I might do is cams, but I would have it dyno tuned after that.
