aviator goggles 4600 with 3/4 helmet
has anyone worn these goggles over a 3/4 helmet? wanted to see if they will fit well when the strap is on the helmet and would seal around the eyes correctly.
if you have pics of it with the helmet, that would be great.
http://www.classicgoggles.com/goggle...y_Code=ref4600
Nice looking goggles. I wear HD goggles with a half helmet. They work okay, but the Avaitor's look like they seal air better. I'm anxious to hear other's input.
OK. I get to help someone save some $$$'s. Those goggles are very nice BTW. I have a pair. They absolutely will NOT fit over a 3/4 helmet and seal around your eyes. Exactly what I got them for and they didn't work. Mostly a waste of my money. The strap will fit under the helmet just fine though. I will wear them on occasion with a half helmet or 3/4, but the strap always gets pushed down into the top of my ears and irritates me. If you had ear pads with a place to put the strap or a goggle strap on a half it would work. But not over a 3/4 because of no seal around the eyes.
Sorry, no pictures. Their other goggle that looks like a ski goggle will work with a 3/4.
Thanks for the info Jolly.
I was thinking the aviators would work/look good with my Bell 500 helmet, but not if the strap must go under the helmet. I am currently using the HD goggles, but that strap must go under the helmet as well. Kind of a pain when they fog up in a light rain and you need to pull them off real fast to see where you are going
thanks for the helpful info. that's what i heard to that if under helmet, they would work if the strap doesn't slide down when you put on your helmet. these are the aviators recommended to me if they're to go over the helmet.
http://www.british-classics.com/Avia...20Goggles.html
One of the guys at work uses a pair of these http://classicpartsltd.com/links/mar...n-goggles.html with a 3/4 helmet, browse round the sight lots of colours and styles to check out. If you move the mouse pointer over the photo you get a zoom, look at where the strap joins the frame and you'll see why it works with the strap over the helmet. You can also get a 2nd set of lenses that are tinted, easy to change over. They are comfortable to wear, I use mine when driving the Jeep with top down and doors off.
