did I just waste 30+ $$$ in oil?
well I just changed all the fluids on the fatty and in the process I forgot to change the filter.... doh!
now my question is... can I remove the filter even though I just put fresh oil in? I haven't started the bike yet so I would think that the motor doesn't have much oil in. Or did I just waste my $$$ and have to do a whole oil change again?
the filter has 3k on it and I run syn vtwin oil.
what are your thoughts?
Have you actually tied this, I would think that most of the oil you poured in the filter would end up in the "tray" I use to catch the old oil when I remove the old filter.
Ain't that the truth!!!
As fas as the OP's question, I would just pop the new filter on and not worry about it. Just recheck the level.
What I was told was to pour in enough oil to get absorbed by the filter element. The theory is the less oil your engine has to pump into an empty oil filter, the faster it developes full oil pressure.
That's a pretty standard part of changing the filter.
