6th gear pull at what speed?
Old 09-17-2010 | 09:29 PM
WildBillHarley's Avatar
WildBillHarley
Since I have a 2009 Ultra, with a tach, i shift by rpms and feel of the bike. I go into 6th around 2500 which is near 65 on my bike. I downshift when the tach gets near 2000. Have always used the tach for shifting when my Harley had a tach. A couple havent and then I just used the feel of the vibration to shift. Each his own as far as shifting but always felt lugging was very hard on a bike and avoid it at all costs..
Old 09-17-2010 | 09:33 PM
bwana1's Avatar
bwana1
So you think it is easier, with less wear on the engine at 2000-2200 rpm than running at 2500-2700 rpm? Ought to ask this question of your crank shaft.
Bwana
Old 09-17-2010 | 10:32 PM
brianmz1's Avatar
brianmz1
If im going to just cruise & hold speed then I'll drop into 6th at around 50mph. But if I have to accelerate I'll drop to 5th.
Old 09-17-2010 | 11:04 PM
Nubz's Avatar
Nubz
Originally Posted by WWECOUGAR
There's a little manual book thing that came with the bike that was written by people who built the bike and might know a thing or about it, and I'm sure somewhere in there is a little chart thing that has your shift points. If you don't have that little manual book thing, they are good to have.
shouldn't put so much faith into manuals with such things as shifting LOL
Old 09-18-2010 | 01:54 AM
TXSwede's Avatar
TXSwede
I never put it in 6th till 60 mph. It just dont like it till then, the engine lugs.
Old 09-18-2010 | 02:53 AM
IronGear's Avatar
IronGear
Originally Posted by inaroush
I have a 2010 Fatboy and in 6th gear at 50 I also pulll quite nicely.. But 6th is really an overdrive gear to put the bike in about 50 or better to bring the rpm's down and cruise with nice low rpm's.... If you need to pull use 5th gear and wind it out.
If you have a manual, I would be looking in the transmission section, and checking the ratios.
Old 09-18-2010 | 03:21 AM
txfxstrider's Avatar
txfxstrider
Originally Posted by Other Sheep
Just keep in mind that lugging the engine is the worst thing that can be done to the six speed tranny. But it's yours. Do what you want.
Huh?
Lugging is bad for the engine but it's certainly not "the worst thing that can be done to a six speed tranny", or any tranny for that matter. Makes no difference to the transmission. Just saying.
Old 09-18-2010 | 04:30 AM
ynots's Avatar
ynots
With any manual transmission you have to select the right gear for the conditions your driving in. if your pulling a steep grade at 60 and your loaded to the max running 6th gear probably isn't a good idea. In totally flat terrain or running down hill with no load on engine you can get away cruising 50 mph in 6th. learn to listen to your freaking engine
Old 09-18-2010 | 08:39 AM
cogener8's Avatar
cogener8
07 RKC with tach. Shift up at 65 and cruise all day long. 60 is gettin down around 2200 RPM starts luggin below 2000.
Old 09-18-2010 | 08:47 AM
dirtracin23's Avatar
dirtracin23
Mileage??? My scoot gets the best MPG in 5th gear running 62-65 mph which is about 27-2800 rpm.
Quick Reply: 6th gear pull at what speed?
