Miles on Tires
Old 09-14-2010, 08:11 AM
frog13's Avatar
frog13
frog13 is offline
Originally Posted by mgreencrna
How many miles are you getting on your tires?
ALL OF THEM!!! It's really hard to log miles without it being on the tires!
I'm almost due for a rear tire, probably make it to about 12,000, the front has 21,000 and still looks real good.
Old 09-14-2010, 08:48 AM
fixedmlc's Avatar
fixedmlc
fixedmlc is offline
around 10,500 when I replaced the back. Front now has 12,000+ on it.
Old 09-14-2010, 08:49 AM
BrooklynBoy's Avatar
BrooklynBoy
BrooklynBoy is offline
Originally Posted by Ultra Street Jewell
I've got 15k out of my back wheel and 28k to 30k out of the front wheel in the past Not sure what I'll get off the 2010Ultra Limited yet.
I'm sorry, but what did you say?
*stares at avatar*
Old 09-14-2010, 09:13 AM
Twofields6's Avatar
Twofields6
Twofields6 is offline
Got a little over 12 on back right now and going to need new one over winter. going close to bald but should be fine until hibernation.
Old 09-14-2010, 09:18 AM
cadman311's Avatar
cadman311
cadman311 is offline
It's all about how you ride. You ride easy your tires are going to last longer. Run it hard they wear faster.
Old 09-14-2010, 09:23 AM
2002flstc's Avatar
2002flstc
2002flstc is offline
Well I only got about 7,000 out of this tire...
Old 09-14-2010, 09:42 AM
kerrycorcoran's Avatar
kerrycorcoran
kerrycorcoran is offline
That statement is kind of correct, however getting 25k plus mileage out of a front tire is UNREAL.
I have 10200 on the back, needs replaced. Front has the same, signs of cupping. I am replacing both with Metzler ME880 Marathons. Will see how the perform.
Old 09-14-2010, 10:59 AM
cadman311's Avatar
cadman311
Try useing Dyna beads in your tire.
http://www.youtube.com/watch?v=eq263AYgyYg
Old 09-14-2010, 11:36 AM
rh8234's Avatar
rh8234
rh8234 is offline
LOL - that looks like the rear tire I have on the Dyna right now (with about 9000 miles on it). It tends to wear in the center for some reason. Maybe it is because I can't pull away from a stop sign or light without making a little smoke. The rear on the Ultra lasts a bit longer (about 11000miles) and the front on the Ultra was just changed at 14,500 - not because it was worn, but because it was dried out and not gripping the road too well.
Old 09-14-2010, 11:46 AM
cHarley's Avatar
cHarley
cHarley is offline
Tire wear is also relative to your geographic location. The higher asphalt temperatures in the southern states softens the rubber compound. It may make the tire stick better, but it plays he11 on tire mileage. The same is also true when it comes to the composition of the asphalt mixtures used in different parts of the country. A coarse grade asphalt just chews the rubber up.
Quick Reply: Miles on Tires
