sert tuning / programing question
Search isn't working...quick question on tuning with the SERT.....when you first plug it in, does it automatically default to which map you are currently running?
I'm trying to chase down a decel popping issue and tried the smoke trick, but couldn't see any obvious signs of a leak. Before I completely remove and reinstall my exhaust, I'd like to see my current map (dealer did it previously) and add a little to the zero throttle if it is currently at zero
Thanks!
Thanks!
No, I believe you have to load a map into the SERT pgm when you start. That's the problem with the dealers when they do your tune, they won't give you a copy of the map that you just spent $300 or more having them do. Complete ripoff. I'd ask around to see who has a map that is close to what you're running on your bike and start from there.
I have a map I could send you but don't know if your bike setup is close to mine.
lt1tyrell
10-24-2010 04:20 PM
