standard V&H slip on baffles
Anyone know of large size baffles for standard round V&H slip on pipes???... mine are not loud enough...I can see all the way through the baffle so I know I don't have the quiet baffles....
thanks,
RED
thanks,
RED
Yep, I sell the adjustable baffles for 2,5 and 3" slip ons with a straight end or slash cut. They are called Bavo adjustable dB killers
I engineered them myself (I am a qualified professional engineer) and they can be manually adjusted in a fe second even with running engine in three steps from a legal 88-92 dB, via 96dB to a painstaking 104-108dB when fully opened.
Tests on sound are made.
In the coming weeks they are available via e-bay..They are manufactured on order.
Can easily be mounted by yourself, with a drill and a spanner. I have them over four months tested on my 88B Heritage Classic with S&S 3" slip ons.
Pics are hereby. If you are interested, mail me private.
The V&H baffles fit pretty snug inside the mufflers. Don't think you can put anything larger in there, it is almost a straight pipe. That baffle is about the least restrictive you can get. If you want louder, try pulling them out and see how it sounds. You can cut the baffle down and make it shorter. And if that's still not loud enough you can try a set of drag pipes. It will run like crap except for WOT, but it will be loud.
