Just Got TOWED - Home
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
I Followed these directions and it didn't work on my Bike or my friends bike
dennyo,
not sure if it works the same on the older bikes, but i just tried my 2010.
first i pressed and held the odometer reset switch, then turned my ignition on. didn't mess with the run/stop switch at all. the speedo did its sweep and diag displayed in the odometer window.
