Teach me old wise ones
#55
Just ganna copy these from BlackBird on that post...
1. Never park your bike downhill into a parking space.
2. Never park your bike downhill without being in gear.
3. Never leave your bike running and unattended downhill.
4. Never stop your bike with the front wheel turned.
5. Use your rear brake as the control brake at slow speeds.
6. Turn your head and look over your shoulder during U-turns.
7. Look where you want to go.
8. Don’t always believe the neutral light.
9. Always downshift to first gear before coming to stop.
10. Check your tire pressure regularly.
11. Keep your eyes level with the horizon when coming to a stop.
12. Practice your starts and stops on different inclines.
13. Practice stopping with only your left foot down.
14. Change your tires when the minimum tread depth is 1.5mm f & 2.0mm r.
15. Be prepared for wet weather; invest in top quality raingear.
16. You will drop your bike no matter how new or old it may be.
17. Unless your leather is lined, the black dye will run when it is wet.
18. You can be cold at speed on a 70 degree day.
19. Dress in layers with adequate air space in between.
20. Two full seasons on an “un-Tendered battery” is reasonable, any more will tempt fate.
21. Take the time to winterize your bike properly for storage.
22. Buy the best helmet you can afford and one that fits. It’s your brain.
23. There is only one thing worse than wet…..its cold and wet.
24. Cornering is the reason we ride in the first place. Become a master of the turns.
25. Countersteering is the #1 way to turn your bike quickly!
26. Pretend you are invisible to other drivers.
27. Ride Your Own Ride: Don't try to keep up with your friends who may be more experienced. Know your personal limits.
28. Make SURE your kickstand is all the way down.
29. MAKE SURE your kickstand is all the way up
30 Never leave your petcock on reserve after fueling
31. Your helmet will fall off that seat!
32. Always leave yourself an "out" whenever you're riding!
33. Don't linger in anyone's blind spot.
34. You NEVER have the right of way on a motorcycle.
35. Always do a shoulder check when changing lanes.
36. Eye contact with the left-turner in front of you don't mean squat.
This is going well I think
Lot's of good stuff coming up.
Drt85
General Topics/Tech Tips
33
01-02-2017 01:26 PM
