HD Factory Security System
Old 01-25-2008, 07:25 AM
SteelCityScooter's Avatar
SteelCityScooter
SteelCityScooter is offline
Default RE: HD Factory Security System
The "basic security system, is just that, BASIC.
It will kill the ignition and set off the lights when activated. You can then "purchase" more features from the MotoCo to make it a more advanced system(sirens, pagers) and the system becomes even better.
One major problem with the 07 and newer systems is the proximity keyfob. It is constantly wearing down the keyfobs batterys because it is always "on". With the pre 07 system you only used battery power when you push the button, so the battery lasts much longer.
A good thing to do is practice the "manual disarming" using the turn signal buttons and the ignition switch, and also to store a spare set of batterys for the key fob on the bike. (for the 07 and newer bikes)
  #32
Old 01-25-2008, 08:21 AM
BULLDOG88's Avatar
BULLDOG88
BULLDOG88 is offline
Just chiming in to support the monthly practice of the manual override procedure. The timing for the code entry is quite breif.
  #33
Old 01-25-2008, 08:50 AM
Flying Horse's Avatar
Flying Horse
Flying Horse is offline
A good feature but best if used with the siren. You could get by with the fork locks and a wheel/brake lock but that takes more time and effort. I like the pre-07 setup better.
mikeo33y
12-27-2016 09:15 AM
EasTexUltra12
01-29-2013 01:53 PM
Verbal
10-08-2012 11:39 PM
pastorralph
11-01-2009 01:28 PM
elambo
07-19-2009 01:17 PM
Quick Reply: HD Factory Security System
