Help? Woman with a Clutch Issue.
I had a stroke. Can't hold up two wheels anymore. Went and bought a 2010 StreetGlide Trike FLHXXX. My left hand is still not very strong. I'm able to pull the clutch, but it's tough. Some say I should install a Muller Power Clutch 1130-0003. Others say I should get a hydraulic clutch. The Power Clutch is a much cheaper option. Any thoughts? Thanks!
MRC otta Vegas. I had to put one in when I got arthritis. Try this link.
http://www.phaedruscycle.com/Page1.html
Much more effective than the kit Harley sells.
Moe Taters
Moe Taters
http://www.amp-research.com/products...otorcycles.asp
The above is a link to a device that uses a spring and gears to help reduce the effort it takes to pull in the clutch lever. It costs around $90.00 or so. My best friend bought one for me after I had crashed on the 91 highway heading east at about 90 MPH or so. It helped me get back on the road on two wheels again much sooner than I would have been able to on my own. I hope that it can help you too! I also installed the MRC unit as well and between the two I was doing fine. After I regained as much of my hand strength as I thought was enough, I removed the AMP device and ended up leaving the MRC unit on the bike. Good luck with your recovery and ride safe out there!
Moe Taters
Moe Taters
Your local HD may be able to get it for you and/or install it for you.
I'm glad you posted your question as I may need to look into one of these for either myself or the wife someday.
The auto clutch is much more expensive and seems like overkill if it's just an easier clutch you want.
It is an interesting product though. Read that it will void the HD transmission warranty but don't know if that's true or not.
I had no clue what it was since there's little info on the Revloc site. Found this review of it which gives a good overview of how it operates in real life:
http://www.patmanracing.com/Tech_Revloc.htm
The "MRC" item has been around for a long time, made by a number of differnent companies. White Bro's were the 1st company to make them. They are inexpensive around $30.00. I have used this type of device on all my bikes since 91, as well as these...
http://www.kuryakyn.com/index.cfm/go...ID/10/IMID/115
http://www.kuryakyn.com/index.cfm/go...tail/IMID/1028
This combination works really well at reducing hand issues...
