synthetic or conventional debate
Old 06-27-2010, 01:41 PM
rhinomac09's Avatar
rhinomac09
rhinomac09 is offline
Stage I
Default synthetic or conventional debate
just want some opinions or pros and cons on the subject
Old 06-27-2010, 01:47 PM
SleeplessinVegas's Avatar
SleeplessinVegas
SleeplessinVegas is offline
Use the search button.
Old 06-27-2010, 01:48 PM
Mal74's Avatar
Mal74
Mal74 is offline
There's an entire section of the forum devoted to OIL~!
Click on it:
https://www.hdforums.com/forum/oil-a...ted-topics-30/
Old 06-27-2010, 02:21 PM
aviator's Avatar
aviator
aviator is offline
since I'm a fence straddler - I mix mine.
Old 06-27-2010, 03:11 PM
rounder's Avatar
rounder
rounder is offline
get synthetic for your air cooled motor.
Old 06-27-2010, 03:19 PM
DocJ's Avatar
DocJ
DocJ is offline
Synthetic is truly the only way to go. It may be said that conventional is just as good, cheaper, etc. BUT, synthetic IS better for your engine and will help it last much longer.
I "googled" and came across this article in SmartSynthetics.com:
Auto Industry’s Best-Kept Secret; Synthetic Oil
Base article is from Muscle Mustangs and Fast Fords Magazine, with additional commentary by members of our group.
Have you ever heard the story about the light bulb that doesn’t burn out or the razor that never dulls? Sure, these stories get exaggerated, but sometimes there’s an element of truth to the rumors leaking out of a manufacturers skunkworks. One particular rumor that sounds too good to be true is “ an experimental motor oil that increases horsepower, practically stops internal engine wear in its tracks and improves fuel efficiency.”
Well, synthetic motor oil is not a rumor. It’s been in use ever since World War II (the Germans used it on the cold eastern front because conventional oil wouldn’t flow in the arctic-like weather). Even though it sounds too good to be true, synthetic motor oil reduces engine wear, improve gas mileage and increase horsepower. This is because synthetic molecules are superior in a number of ways to mineral-based oils.
Synthetic Oils are Superior to Mineral-Based Oil in Every Way:
Without getting too technical, suffice it to say that synthetics have a much higher resistance to heat than mineral-based oils. Because synthetic oil is composed of molecules that are uniform in weight and shape, its heat of vaporization is much higher (more than 600 deg. F.) compared to conventional oil, which begins evaporating at temps as low as 350 deg. F. This added stability at high temperature means that your hard-working engine wont burn up as much oil- and that means less sludge and fewer varnish deposits in the engine.
Added lubricity is another attribute of synthetics. The uniform diameter of synthetic oil polymers allows them to more easily slide over one another. The resultant reduction in friction shows up as more horsepower and torque and reduced internal engine wear.
Higher film strength, however is one of the major benefits of synthetics. Film strength is what keeps oil molecules from being pushed away from each other under pressure. Mineral based oil has a film strength of about 400 psi, while synthetics usually exceed 3000 psi. In an area where two metal surfaces meet, the film of oil between them prevents them from rubbing and wearing away at each other. Synthetics do a better job of this than conventional mineral oils. It takes more than seven times as much pressure to squeeze synthetic oils from between two surfaces than mineral-based oil. Consequently, synthetics are much better at keeping your engine like new.
Not All Synthetics Are Created Equal:
Please be aware that not all synthetics are created equal. There is wide differences in quality and protection provided by the various synthetics. Additionally, not all synthetics are 100% synthetic. Many are partial synthetics marketed under the perception of full synthetics to the unsuspecting consumer or even hydrocracked oils such as Castrol Syntec, for example, which is a hydroisomerized petroleum oil marketed under the disguise of a synthetic (there is a full article on this in our Informative Articles section detailing the recent battle between Castrol and Mobil). There are no PAO (polyalphaolefin) synthetic molecules in Castrol Syntec, yet because of legal finagling with the definition of synthesized motor oils they can legally be called synthetic. Basically, they changed the definition of a synthetic to fit their process of highly refining a petroleum base oil, called hydrocracking and fought with Mobil and the National Advertising Council to loosen the definition of a synthetic.
Film strength is important in another way- cold start protection. Regular mineral-based oil will not remain as a boundary layer (a uniform thin coating) on metal surfaces when an engine is turned off. Mineral-based oil drains off parts and out of passageways into the oil pan. Additionally, mineral-based oils contain waxes and paraffins that come out of the earth and solidify when it gets colder outside, therefore making it even harder to pump the oil when cold. When you crank your vehicle the metal surfaces (crankshaft, camshaft, lifters, connecting rod bearings, piston pin bushings & bearings, piston, rings and cylinder walls) that require lubrication are not fully lubricated in the time it takes for the oil pump to pressurize the lubrication system and supply oil to the engine.
With Mineral-Based Oil Your Engine is Not As Well Protected During One of The Most Critical Times: Engine Start-Up:
Engine start-up lubrication is one of the most critical times for lubrication. Small amounts of wear occurs every time you start your engine with mineral-based oils. Over time, these small amounts of wear add up to larger amounts and result in increase clearances, reduced oil pressure, increase oil consumption and reduced life of your engine. Synthetic motor oil, on the other hand, will stay on engine parts and coat them uniformly because of its high film strength and greater heat affinity (it adheres better to hot metal parts). Additionally, synthetics prevent start-up engine wear and are pumped to critical passageways, surfaces and bearings much faster than mineral-based oils. With mineral-based oils your engine is basically running with no oil (which can be as much as 20-30 seconds, depending on the severity of cold weather, after cranking the motor). With synthetics after several hundred thousand miles you still will have a strong running engine, instead of a used-up engine that may require a re-build. This has been proven by millions of miles of customer usage and countless laboratory and field tests.
(As an extra benefit , some synthetics are designed for longer drain intervals. This offsets the added cost of synthetic oils. AMSOIL has motor oils designed for 25,000 mile/1-year or 35,000 mile/1-year drain intevals (or longer with by-pass filtration). There is no other oil company in the world that can match AMSOIL’s extended drain interval capability or quality).
Okay. Synthetics are great. The real question is: Why doesn’t everybody use them?
Interestingly enough, the biggest reason that synthetic lubricants are not in widespread use is because the would-be consumer does not know of the benefits provided by synthetics. Also, they are not sure where to go to ask or who to ask. Asking your local parts counterman at the auto parts or the high school kid at the quick-lube shop is not the answer, or even asking your local auto dealer that sold you the car- remember, they are usually tied in with the manufacturers brand or oil and the 3000 mile oil change myth. You should seek out and acquire information from a Certified Lubrication Specialist, lubrication engineer or unbiased automotive engineer or competent mechanic that fully understands and can explain the benefits of synthetic motor oil and the drawbacks of mineral-based oil to the consumer. But beware, there are many mechanics out there that are so engrained in the old way of thinking that they refuse to change their way of thinking or even open up their minds to the fact that there are automotive engineers, lubrication engineers and chemists that know a heck of a lot more about motor oils, filtration, vehicles and synthetics than them.
Some People Will Never Change:
Also, even though people have known about synthetics for years, consumers continue to be brand and price driven. The rationale continues to be, “My grandpappy used brand V in his model T, so I won’t use nothing else.” Or, “I been using brand Q in my IROC for years. If I change brands now I’ll blow the motor.” Or, “ I ain’t payin’ no five dollars a quart, no siree, Bob, I ain’t that stupid.” Or, “I ain’t using none of that synthetic oil...that’s stuff’s made out of beans...I want some real crude oil.” (this last statement was an actual statement from a customer in a snowmobile store. He was having 2-cycle spark plug fouling problems due to the mineral- based oil mixture he was using. The store suggested he use synthetic oils and 2 new spark plugs to eliminate the fouling issue. He declined and purchased 2 boxes of spark plugs and his usual crude oil mix ; guess some people will never change).
Synthetics Are Compatible With Mineral Based Oils, But Be Careful:
When switching to a synthetic motor oil, it is important to keep several things in mind regarding oil consumption. Keep extra quarts of synthetic handy. Although many synthetic oil manufacturers tout the compatibility of their oils with mineral-based oils, adding mineral oil to synthetic oils will drastically reduce the level of engine protection that was initially designed into the synthetic oil as well as the mileage to your next oil change. Also, as the mineral oil breaks down it will contaminate the rest of the oil, leaving sludge and varnish deposits in the engine (this is because mineral oil is made up of many chemically dissimilar hydrocarbons, including waxes, all of which react differently under different operating conditions). By adding a mineral oil to synthetic oils you will also see a reduction in engine efficiency. depending on how much, and when, the mineral-based oil was introduced.
There are many different companies that offer synthetics. because this overview is intended to give readers a general idea of the benefits of synthetic lubricants, we have not discussed the specific differences between all the individual brands and their formulations. Keep in mind that there are significant differences between brands of synthetics, which will affect the performance and longevity of your engine, transmission, axles, bearings and chassis components.
Read more: http://smartsynthetics.com/articles/...#ixzz0s5Qr8o2Y
Old 06-27-2010, 03:20 PM
coupe55's Avatar
coupe55
coupe55 is offline
Default 07 & Up
Run a little hot, would probably run synthetic! See oil threads for the reason why!
Old 06-27-2010, 03:46 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is offline
Since this is your first post and you are already inquiring about oil I would suggest you learn how to search. You can either look around this site or use a search engine and scour the internet. When you are done reading all the opinions that are easily available if you still have questions then come back and ask. This alone should take you about 2 weeks.
Old 06-27-2010, 03:55 PM
2kids3pets's Avatar
2kids3pets
2kids3pets is offline
Run what is cheapest, chances are you wont have the bike long enough to make a difference.
Old 06-27-2010, 05:08 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
There was a guy many years ago that had over 400,000 miles on his harley. He used Harley 360 dino oil.
I use both. Sometimes I run syn and sometimes dino. Right now for instance I have Valvoline VR-1 racing 60wt which is dino oil but still works great in the heat. I couldn't find any Redline 20/60 and I rack the miles up and will be changing it out in the next few months.
Quick Reply: synthetic or conventional debate
