Wheel weights
Old 06-30-2010, 02:18 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
Default new hope
This conversation had me concerned about the 20 wghts on my rear wheel, so, i cut one off the wheel to read the small print. It turns out that each one says 5 grams and .18 oz. My math calculates these numbers to right about the 3.5 oz harley allows, I think. wHY DOES IT HAVE TO BE SO HARD FOR A LAYPERSON????? by the way, they are not lead or steel but i dont know what they are made of either. Any help??
Old 06-30-2010, 05:06 PM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
Instead of putting 1 big one on like the stock wheel came with they put on 7 smaller ones. Did the same to mine but only 4.
If you don't like the way they look take them off and put some dyna beads in.
Old 06-30-2010, 06:05 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
that is always an option, someone locally must sell them.
Old 06-30-2010, 07:55 PM
dawg's Avatar
dawg
dawg is offline
Received 3,134 Likes on 1,797 Posts
A dealer search on innovative balancing showed 8 dealers within 25 miles or Irwin, PA
Old 06-30-2010, 09:05 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
Default OK Dawg, thanks for looking that up.
Is there a process/formula or a method to determine how much should be inserted into the wheel. What if too much is used and how do you know??? I know they are sold by the ounce, seems like guess and go to me.
Old 07-07-2010, 03:07 AM
dvldg1234's Avatar
dvldg1234
dvldg1234 is offline
Actually, I just counted them. I've got a total of 4 ounces of weights.
Old 07-07-2010, 05:48 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Dyna Beads are the wa to go.
Old 07-07-2010, 06:12 AM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,230 Likes on 1,292 Posts
If I was to switch to using dyna beads, would I need to remove the existing wheel weights on my spokes or just leave them there?
Old 07-07-2010, 06:38 AM
xFreebirdx's Avatar
xFreebirdx
You will need to remove them.
Old 07-07-2010, 12:13 PM
mattman22033's Avatar
mattman22033
mattman22033 is offline
Originally Posted by xFreebirdx
Dyna Beads are the way to go.
I run Avons with Dyna beads.
Quick Reply: Wheel weights
