Don't spin on oil filters seem outdated?
Before the mid sixties paper cartriges were the norm but they usually made more of a mess, thats why the manufacturers went to spin on.
I used to have a Saturn ION that had a housing with a cap that the oil filter dropped down into. No mess at all when changing it, I have often wondered why all cars do not use something like that. Quick and easy....
Phil
Phil
BMW cars have a similar filter. It is a metal cylindrical housing. You remove a bolt that goes trhrough the housing cover and filter, take the cover off, take a small plastic bag, grab the filter turn the bag inside out and your done. Then you drop a new filter in, add a little oil and put the cover back on and tighten the bolt.
I remember "Back in the Day", when Chrysler products used a can on the firewall that you put a roll of toilet paper in to filter the oil. At least the filter insert was cheap...
I`d rather see the new spin-ons used as the Old HD`s that didn`t use a filter at all....
Remember, the oil filter is fully pressurized. An air filter only has to deal with at most about a 15 PSI pressure differential, oil filters will hit 4-5 times that much pressure on a cold start. On top of that, an air filter deals with negative pressure (pressure outside the filter housing is greater than pressure inside) which actually helps the filter seal more tightly as the differential increases; oil filters deal with positive pressure (pressure inside the filter is greater than pressure outside) which works against the seal. What works to seal an air filter isn't going to cut it for an oil filter.
A lot of newer Euro cars are switching back to cartridge-type oil filters, but it's to reduce the amount of material used to make the filter and to provide greater flexibility in where the filter is mounted, not to reduce oil spillage.
[QUOTE=Romark;6913857]I just pull the plug and let it drain on the ground. Thats where oil came from in the first place. I'm just putting it back where it came from.
Many Moons ago up in the woods when I was loggin' running' Skid CATS and dozers and such, when it came time to change oil, I`d just gouge out a big trough in the ground, pull the machine over it and the mechanic would pull the plug and drain the oil into the trough, usually anywhere from 9 to 13 gallons depending on the size of the machine and engine, along with the filters both oil and hydraulic. When done, I`d back up and fill in the trough with the dirt I had taken out. Usually with a little extra just for good measure. Back before the days of EPA and tree huggers and other environmentalists. They`d probly frown at ya real big nowadays.........
