Road King Pulls to the Left
Hello All;
I was reading some posts about Road Kings pull to the left when you take your hands off the bars. So I set the cruise and took my hands off the bars, low and behold it pulls to the left.
How common is this?
Is there a fix?
Thank you in advance
How common is this?
Is there a fix?
Must be a Democrat.......Typically, throwing gobs of money you don't have at it will just make it worse.
If you have any change left, try putting it all in your right pocket.
Here is an idea. If you have perfectly aligned bike but weight on right side is higher your bike will not be vertical and it will pull to the left.
I hope it is good enough explanation.
If your *** is not centered bike will go "no ***" side.
