Wheel Bearing Blues-Help!
Old 06-23-2010 | 08:36 PM
ga guy's Avatar
ga guy
All bearings are standard. If I need a bearing I measure it and call bearing store. Open yellow pages book. Guess where? Bearings page!
For example, if AC compressor in your car is bad you can spend $10 for new bearing or 300 for new compressor.
Old 06-23-2010 | 09:21 PM
Zig Zag 2010's Avatar
Zig Zag 2010
Old 06-24-2010 | 11:12 AM
Fastfwd's Avatar
Fastfwd
I sure do hate to hear this, but that’s what the service guy told me on my bearings issue……he said he’s seen a lot of Dyna’s especially in recent years with bad bearing issues……
https://www.hdforums.com/forum/general-harley-davidson-chat/519328-09-rear-bearing-failure.html
They had to replace my entire rear wheel – you can’t buy the hub seperatly…….if that hadn’t been warranty covered it would have been astronomical….. all because of those shitty bearings.
Old 06-24-2010 | 12:20 PM
FastHoss's Avatar
FastHoss
A trick we use here in our truck shop ( we use cheap bearings ) is to remove the seal and add grease to the bearing and put the seal back on.This makes them last so well that the bearing rep called me to see why I stopped buying bearings from them.
Old 06-24-2010 | 04:52 PM
dope_man_21's Avatar
dope_man_21
WRONG
The bearings I ordered that are a direct replacement for the stock bearings DO NOT match anything in the local bearing supply house, in diameter yes, bore yes, load rating, not even close, thickness, any one is too narrow, and I thought what about two bearings in place of one, no combination of any of the two would equal the width and give the correct load rage needed to match the stock and/or stock replacement bearing. I had our local bearing supplier for work look for replacements (like it was for work) and they could not come up with anything, was told to contact the machine manufacture and order the bearings from them, and then have them match them, so I took them what I had purchased and again nothing, two days wasted looking. In the end I ordered them off of Ebay for less than $8.00 each.
Old 06-24-2010 | 07:23 PM
xwhyz1959's Avatar
xwhyz1959
Look for your nearest Motion Industries store. They can match anything for anything.
FATKEVIN
08-20-2015 05:48 AM
Shaved Ice
07-12-2013 08:51 PM
oldschoolhd
05-23-2012 10:51 PM
rodney123456
04-05-2010 03:57 AM
rider
09-30-2007 05:26 PM
Quick Reply: Wheel Bearing Blues-Help!
