Clutch problem
Old 06-21-2010 | 09:11 AM
HDSAE60's Avatar
HDSAE60
I once saw a steel ball used as a spacer, it lived between the clutch push rod and the adjustment stud on the basket. maybe you lost your steel ball?
Old 06-21-2010 | 12:33 PM
Tomcatt78's Avatar
Tomcatt78
The bolt sleeves are loose so maybe thats one place to start. Thanks for the tip. I didn't want to have to tear the whole thing apart again but its looking like I may have to. If the key came out of the slot, could that cause the clutch to not disengage? How do I move this thread to the EVO section?
Old 06-21-2010 | 03:10 PM
Free Willie's Avatar
Free Willie
What do you mean by loose? they will flex a little but are they spinning?
Sounds like you're on the right track.
If the key came out of the slot it normally would jam up between the clutch basket and trans shaft seal making the clutch assembly sit crooked on the shaft & wobble when rotating. If it just fell out you should find it in the primary.
Hope this helps, I just put a new basket in my 84 shovel. It has the same diaphram setup you have. Cost $200 for the basket if you messed up one of those sleeves.
Old 06-21-2010 | 05:45 PM
Kabear's Avatar
Kabear
Ask one of the moderators to do it for you.
Also make sure the spring thing is centered on the clutch and the bolts that hold it together are properly aligned within the slots. Make sure that there are two pushtubes going through the input shaft. Also you need to check the .010 measurement on the spring. Don't forget the 3/4 in. setup on the arm. This is sort of difficult, I made a massive feeler gauge out of a piece of flat steel, actually a rafter tie in plate. Setup the adjuster tighten until all slack is out then back out 1/2 to 3/4 turn.
Old 06-26-2010 | 03:43 PM
Tomcatt78's Avatar
Tomcatt78
I had the bike out today for a quick ride and everything seemed fine. It shifted good through the gears so the clutch is working. It started pulling away the first time I put it in 1st gear with the clutch in but after that it did not move with the clutch pulled in and going into 1st. I guess I was looking too much into things. Either way, its working fine. Thanks for all the advice, it was a big help!
Just Don
03-23-2014 09:20 AM
tonycap
EVO
14
05-24-2013 11:44 AM
jmass
05-12-2010 10:58 AM
Kyddworks
07-25-2009 12:43 AM
Chuck_1550
10-11-2008 05:29 PM
Quick Reply: Clutch problem
