c.v. carb issues
Bottom? The screw you should be adjusting is on the side - #354 on the diagram. That screw that you are talking about (under the aluminum plug) is about three full turns out on mine. Shouldn't affect idle speed, but will affect warm-up time and lean conditions you describe.
If you have an air leak, the plugs may be light tan color, but spraying a little WD-40 around the intake joints would be better.
Yeah guys, it is #150.......better to have the carb actually in front of me I guess. All valid points mentiomed above. That #342 diaphragm can be hard to seat properly and get pinched. Did that once, and it's about $40 to replace.
wow now im confused.
had this carb on my sporty,(diferent jets), and always adjusted the screw at the bottom. i thought this adjusts the fuel to air mixture at idle.
the screw at the cable bracket 354 or 150 adjusts the tension in the throttle cable. i always adjusted that so theres a sight play in the cable, while resting on the stop.
then adjusted the fuel to air mixture screw (the bottom), to set my idle.
whats right?
whats right?
whats right?
whats right?
And speaking of carbs, I can't beleive how much S&S carbs jumped in price over the last few years. I bought a super-e complete kit not long ago for like $280. Now they are $450.
whats right?
whats right?
Like several people have said - part #150 in the diagram is the idle speed adjustment. However, if turning the AFR screw all the way closed or all the way open does not effect the way it runs at all, I suspect either improper jetting, float adjustment, or possibly an air leak.
what type of adapter are you using?
it sounds like an air leak for sure, get one of those propane torches wit hthe 2lb blue tanks start teh bike up and hold the torch on but UNLIT close ot the seal points where the adapter meets the carb, the adapter meets the manifold, and where the manifold meets the heads. if there is even the smallest leak the propane gas ill be sucked in and change your idle rpm noticabley letting you know where the leak is
