starter issue ???
starter issue ???
tryed starting my evo yesterday (guess batt was weak) and couldnt get it to start but and now it sounds like starter is just spinning freely not cranking the motor pulled starter and everythin looks good any ideas why the shaft just spins freely that goes into the trans did somthing break just wondering if any body else has had this problem before i tear it apart
I have an update, hoping these pics may help resolve the issue. Ive removed the derby cover and looked into the the primary while someone else is pushing on the starter shaft. Here's what I've found.
The lip where the red arrow is pointing to is bottoming out on the back of the primary cover (see second pic with red arrow) When this bottoms out it does not allow the pinion gear to make contact with the clutch sprocket.
Also notice the area where the yellow arrow is pointing. There is slop in the pinion shaft. Is that normal? It would seem if there was not slop in the shaft the pinion gear would be able to make contact with the clutch sprocket
Inside of the primary and the thrust washer
