Torque specs
Old 06-10-2010 | 07:42 PM
xd.404life's Avatar
xd.404life
Default Torque specs
Fist time using a torque wrench and have a quick question on the listed ranges. Is it a range (ex. 120-168 in-lbs for rocker boxes) and as long as you are between the numbers you are ok or is tighten to the lower value first then go back around and tighten to the higher value. Thanks in advance.
Old 06-10-2010 | 07:56 PM
jimmers1817's Avatar
jimmers1817
I generally split the between the high and low ranges. If it's 80-100 in lbs., I go 90.
Old 06-10-2010 | 08:02 PM
xd.404life's Avatar
xd.404life
Thanks a ton Jimmers, kind of what i thought just got to second guessing myself.
Old 06-11-2010 | 06:59 AM
carlgrover's Avatar
carlgrover
When I torque down hardware I usually set the torque wrench to the middle of the torque listed in the manual. However; this is for the FINAL torque. Let's say the torque for a given set of bolts is 150-200 ft/lbs. The bolts should be torqued down in stages. Go around all bolts the first time with the wrench set at 50 ft/lbs. Reset the wrench to 100 ft/lbs and hit them again. Now do a final set of 175 ft/lbs and do a final torque.
This will ensure that everything is tightened down evenly.
Old 06-11-2010 | 07:53 AM
dog155's Avatar
dog155
Certain parts in my motors get the full boat,unless ARP specifies stretching in their hardware as in their rod bolts on my hot rod V-8's.Harley motors get what the factory or after market specifies.
Old 06-11-2010 | 07:56 AM
1flhtk4me's Avatar
1flhtk4me
............when you follow the torque sequence.
Old 06-11-2010 | 08:17 AM
2kids3pets's Avatar
2kids3pets
Just remember inch lbs are different than foot lbs
oldtoad
General Topics/Tech Tips
04-04-2019 07:21 PM
wolfydude
02-21-2009 01:04 AM
twilliams
06-20-2007 11:16 AM
dawg
11-01-2006 02:54 PM
campdreamer47
01-30-2006 01:50 PM
