My carb can't hold it
Old 06-09-2010, 11:10 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
It's probably a cv carb. Google it and you'll likely find a diagram.
Old 06-09-2010, 11:15 AM
96roadking's Avatar
96roadking
96roadking is offline
I know there is a good diagram on the net. I had a link to it when I had my Sporty with a CV. I'm at work now, so I'll look for it when I get home.
Old 06-09-2010, 12:29 PM
pleasants9's Avatar
pleasants9
pleasants9 is offline
yeah i found a good one from google, but now of course another prob, one of the screws holding the bowl on does not want to budge, ill keep carefully working on it so not to strip out the head
Old 06-09-2010, 12:33 PM
texas_speed_freak's Avatar
texas_speed_freak
texas_speed_freak is offline
Originally Posted by JayinPA
The true lazy man would ride it like it is and not give a damn.
Haha. Did that for awhile on my dyna. Just turned the gas off everytime i got off the bike.
Old 06-09-2010, 01:04 PM
95custmz's Avatar
95custmz
95custmz is offline
All the carb info you'll need can be found at www.nightrider.com.
Old 06-09-2010, 01:18 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 15,161 Likes on 6,705 Posts
http://www.twowheelsforever.com/imag...iagram_728.jpg
Basically,
The four float bowl screws will have one longer than the others. Mind where it goes.
Once you get the bowl off, slide out the rod (294) on the carb body side, it should come out from one side only.
Carefully lift out the float (300) and needle assembly (360)......don't bend the tang.
Clean out the bowl, blow some air through the passages.
Inspect the needle seat for debris.
Assemble.........check that float moves freely. Sorry, I can't remember the float setting. 11/32"???
Old 06-09-2010, 01:45 PM
o/d's Avatar
o/d
o/d is offline
not sure about your specific carb, but usually there's an o-ring for the needle seat. they will dry out & shrink over time & let fuel by.
as for the screw you cannot remove:
usually helps to get the screwdriver seated in the head & give the end of the screwdriver a light tap with a hammer.
if the threads are stripped you may be able to get a pair of needlenose vise grip pilers on it. or you can try to dremmel a fresh slot & use a flatblade screwdriver.
good idea to replace them with cap screws one you get them out. sears has a prety decent hardware selection.
smittyhasahog
06-12-2014 06:17 PM
01 chopper
EVO
04-08-2013 05:06 PM
randybecker
09-14-2011 11:29 PM
jaredb
EVO
20
04-04-2011 08:07 PM
edjhover
EVO
11
08-21-2010 08:44 PM
Quick Reply: My carb can't hold it
