Headlight bulb top/bottom?
Old 08-20-2006 | 04:13 PM
JBA111's Avatar
JBA111
Default Headlight bulb top/bottom?
I replaced my 99Ultra headlight bulb with a HD bulb and Now it's like the top of the light pattern is dark. I can light up a wall from 30ft and the patterm on the wall is like I covered the top 1/4 of the headlight bulb with my hand or something. It's preaty noticeable when I pull in from the street and my driveway starts uphill. The HI beam does not Do this, and there is good light from both the hi an low beams.
Is there a top and bottom to these headlight bulbs? The replacement seemed to fit in and wire locked in place correctly. And there wasn't any problems at all durring the reassembly.
So does anyone have a clue as to why there would be this NO LIGHT area? Thanks JB
Old 08-20-2006 | 10:54 PM
Ram's Avatar
Ram
Default RE: Headlight bulb top/bottom?
You may have the lamp in upside down. Take off the trim ring and remove the lamp and rotate it only 180* and re-install it. Then take for a nite test ride.
If that is not helping your lamp maybe defective.
Old 08-20-2006 | 11:02 PM
DGlide04's Avatar
DGlide04
When you replace the bulb it is important that you don't touch the bulb itself as the oil from your fingers and hands can cause hot spots which can lead to problems. Other than that, it couild be a bad bulb.
Old 08-22-2006 | 12:44 AM
JBA111's Avatar
JBA111
Yea I was extra careful to not touch the bulb so that should rule out. As for rotating the lamp, I guess that's my next try. I just hated to go thru that. but I thought with the ears and notches there was only on way for things to go back. And the clear headlamp globe that has H4 on it shows it is rightside up. So I'll take it out again and check everything out and let you guys know. Thanks JB
benscratchin
Electrical/Lighting/Alarm
09-20-2017 09:53 PM
modular
01-26-2015 09:51 AM
DPete
08-04-2010 11:52 AM
yoseppi
04-26-2009 10:54 AM
itznin
08-20-2006 10:34 PM
Quick Reply: Headlight bulb top/bottom?
