Plastic bag stuck to exhaust pipe
There I was, riding down the main drag in our little town, when I see this plastic bag blowing around in the street. I try to miss it, but the wind blows it right back at me. I look in my rear view mirror for it, but it is no where in sight. I pull in to a service station, and sure enough, it's stuck to my exhaust pipe. I pulled off what I could, but still have a strip about an inch wide, and 12" long. Anybody know of a good way to remove the remains? Thanks
A flexible razor blade will work.Like the kind in box knifes.
Used one on mine and scraped the burnt goo off easily and no scratches.
It'll wear off eventually. Chrome pipes? I had chrome pipes on another scooter that got a bag stuck to em.. I just kept riding like normal, washing the bike when it got dirty.. stuff fell off or burned off on it's own. There is probably some good stuff to use, but I never bothered with it. I've done the same thing with rubber from the bottom of a shoe (not mine).. left it alone kept cleaning the bike like I normally would. It all came off eventually.
Thanks for the replys guys; When the pipes cooled, most of the plastic peeled off. The little bit of residue that was left, I scraped with a knife blade held almost flat. That got the rest of it off without scratching the pipe. Chrome drag pipes by the way.
Heat the pipe
Use Aluminum foil rolled into a ball to scrape the oven cleaner on the mark that is still there. Foil is softer than the chrome and it won't scratch it. Works every time.
Had the exact same problem the other day. Came off real easy. Just ride until the plastic heats up, becomes, soft and bubbly and wipe off with soft paper towel or terry cloth rag. This method does not require any cleaners that will damage paint with over spray. You just have to be very careful not to touch the hot pipes and you can't wait for them to cool because the plastic will just start to harden again.
WOLFE1584
07-01-2019 09:09 PM
hilts
08-10-2013 10:20 PM
hilts
08-08-2013 08:46 AM
