Sportster jets sizes
Hello there, I apologise.... I'm new to this forum type thing. I have a 1996 1200 Sportster Sport, which I believe that when I bought it in 1999, it had already had engine work, K&N filter, Screaming Eagle cams and ignition. I have fitted 2" straight thru exhausts and a belmouth intake with a fine stainless mesh. She is popping thru the carb and backfiring on the over run. Is the mixture to weak? I have looked at the jets and this is where I am getting confused; the main jet is marked 210 and the other is marked 3.4
I am not good with computers, but everything I can find suggests that the 'normal' main jet sizes go up to 190. I can only assume that the jets have already been increased. Can (should) I go larger? Also, the other jet (marked 3.4) doesn't seem to match anything I can find.
If I can improve the jet sizes, would it be just a case of removing existing and fitting new, or are there other procedures I need to carry out?
Any help on this subject would be very gratefully accepted. Thank you for reading. Zippy13
Hi Zippie. What type of carb is it? @ inch strait pipes are the worse choice in pipes you could use. They have no back pressure and cause more issues the 2 girl friends and a wife. The stock CV carb has a 42 pilot jet, and around a 165 main jet. 210 seems way too big. I would use a 46 180 combination, and 1 3/4 pipes for better performance. Good luck.
Received 1,297 Likes
Fixing the carb for correct mixture is the least of your problems. With that intake system you're gonna trash the engine in a very short time, assuming you're street riding and not building a competition only bike.
thanx for your input guys, I think I will just revert to a more appropriate 'filter', even tho the bellmouth looks LUSH! I've been running the 2" staright thrus 9 or 10 years now with no problems before vanity gripped me with this 'trumpet'! Have no problems with pillion as she is a solo seated bobber. I got a Ural combo and a Honda VTR1000 if the wife wants a spin
