Buttonless FOB
Buttonless FOB
My 07 Roadster security system is acting up. The blinkers will flash when I try and start it up..nothing happens, then if I cycle the ignition several times it will start. Other times it will start normally. The system has never been "PIN'd" and if I try to enter a PIN I don't get the proper responses. The FOB battery has never been replaced. I will replace the battery, though it shows 2.75 volts. Any suggestions? Can the security system be "turned off " permanently? I wish there wasn't one installed in the first place.
If you bought it new, call the dealership and ask them what the pin is. They usually set them all the same and something simple like 12345. Then check your owners manual on how to change it. That way you won't be screwed if you loose your fob or the battery dies while your out.
In this case I agree with the others that it's the battery in the fob.
1004ron
12-09-2014 03:18 PM
Potato_Potato
05-23-2014 10:38 PM
craving94509
07-04-2013 08:46 AM
tmitchellof PG
08-26-2008 10:28 PM
