Battery powered soldering gun?
Old 05-20-2010 | 06:18 PM
neverdown's Avatar
neverdown
Default Battery powered soldering gun?
Such a thing? I live in an apartment and my bike is in the garage ouy back, no electricity, dont have a 200 ft extension cord.
Old 05-20-2010 | 06:22 PM
Puggy's Avatar
Puggy
There may be one that's battery powered, never seen one, but maybe. An alternative is a butane soldering iron. I had one at work years ago that worked great till someone decided they wanted it worse than I did. Filled it with the pressurized butane cans. It was about the size of an oversized ink pen. Would get the job done and quick. Hope that helps......
http://www.alliedelec.com/search/pro...px?SKU=3100046
Something like this........
Old 05-20-2010 | 07:14 PM
hollowpoint's Avatar
hollowpoint
Before electricity soldering irons were heated with a flame.
I've got one in the shop. It has a wooden handle & a pyramid tip.
You could make one out of a wooden handled screw driver.
I expect batteries would drain pretty quickly.
Old 05-20-2010 | 07:16 PM
myfhfb06's Avatar
myfhfb06
Just buy a handheld torch. Works pretty good.
Old 05-20-2010 | 07:20 PM
hatchetman's Avatar
hatchetman
Old 05-20-2010 | 07:33 PM
not_so_newb's Avatar
not_so_newb
i've tried a couple of battery powered soldering irons and they
1) go through batteries like a vibrator at a lesbian convention
2) don't make enough heat to solder anything much bigger than telephone wires . forget about the wires going to your headlight or anything larger
butane is your best bet for portable
or you could get a 12v dc to 120v ac converter and run a real soldering iron off your battery for a while
Old 05-20-2010 | 07:50 PM
doghair's Avatar
doghair
Butane. I used to use them installing cell phones and radios in cars, perfect. Torches are good too but can be a bit much depending on what you are soldering.
Old 05-20-2010 | 08:14 PM
back again's Avatar
back again
home depot has the butane ones for 10 bucks or so.You'll solder like a pro as soon as you pick it up.
Old 05-20-2010 | 08:34 PM
Jim Kraft's Avatar
Jim Kraft
I have a Wahl battery powered soldering gun that I have had since the 70's. I do not know if they make them anymore, but it worked very well. Instant hot, and would do the same job a 110V Weller would do. It has nicad rechargable batteries, and would solder quite a few joints before needing a recharge. I have replaced the batteries a few times over the years, but all in all a good unit with replacable tips.
Just checked; Just google Wahl soldering iron. They still make them.
Old 05-20-2010 | 09:39 PM
piasspj's Avatar
piasspj
Actually those are called a soldering copper. They work but not as good as the butane ones. The copper pyramid tip holds heat for quite a while, A screw driver won't work near as well if at all.
