Primary change
I recommend you get a manual for your bike before you do anything. I change oil in four places on my two HD's. The engine,primary,transmission, and forks. My primary has no filter in either bike but my engine oil does. I don't have an Electriglide so I don't own a manual for your model or year. Oil change intervals are discussed here often with a lot of disagreement. I change oil in my engine and primary every 2500 miles. Transmission every 5000 miles. Fork oil once a year. It is what I do --others do other things.
I average 15,000 to 20,000 miles a year on the two HD's I own. With the exception of this winter I ride 11 months out of the year. This winter sucked and I was lucky to find dry weather that wasn't cold rarely for three months when I wasn't at work. How many miles do you get a year?
The primary usually takes between 26-32 ozs. Check your manual. And don't add 4 quarts on a oil change. Start with 3 and add a little at a time while checking your dip stick. By pouring in 4 quarts you will be siphoning some out. I do both at 5K using syn, mobil 1.
Buckinfitch
12-04-2016 01:43 PM
TheNameIs"B"
Oil Archive (no new posts)
04-25-2011 08:52 PM
