Laying the bike down
My thoughts exactly. I've met a number of guys who firmly believe that laying the bike down in an emergency was a perfectly valid option. My problem with that is two fold. First, the coefficient of friction between rubber and pavement is much higher than the coefficient of friction between metal and pavement. The bike will slow down a LOT faster on it's tires than it ever will sliding on it's side. Second, once you've put it down, you've forfeited all options. At least while you're on the tires, you have the possibility of braking or maneuvering to avoid whatever it is you're trying to avoid. Once you're on the ground, you're simply sliding along for the ride. If you get to the point where you "have" to lay it down, you've probably screwed the pooch ten times over already, in terms of riding judgment.
To each their own!
Ride Safe,
Steve R.
To each their own!
Ride Safe,
Steve R.
If you have time to finesse that and "ride it like a sled", then you had time to avoid it in the first place.
Anyone stupid enough to "plan" an evasive maneuver based on a pending crash shouldn't get an 'M' license. It can happen so fast, you won't even see yourself bleed.
Have you ever watched a bike high-side during a motorcycle race? It's pretty violent. In that type of situation, it would be better for the rider to lay it down. A typical street rider probably wouldn't ever get in that situation or know how to react, but I know on a dirt bike if you start to have the rear slide out when braking through a turn and then let off the brake the bike can come back up pretty fast. Imagine doing that with soft compound racing tires.
Again, if an average rider like me said they were riding on the street and they chose to lay it down it's probably a bunch of BS. But if a professional racer said they were at a track and they chose to lay it down rather than risk a high side I'd believe them.
Bob B. Road Captain Mt. D HOG
I've had mine down all over CA Best thing to do is not have it happen. But if you do and your on a street or freeway. Get away from the bike as best you can. Roll if possible to cushion the fall. 1st time the bike (my softail) landed on my left foot then I dropped it on the right side and broke my ankle still have the plate and 9 screws. Dumped my Road Glide twice in a few months last year the 2nd time cracked my pelvis is 2 spots back still hurts. This year about 2 months ago took the softail down again and fractured my colar bone and a rib. All but 1 I feel were driver error. Hint don't make errors and as soon as possible if your going down for sure as mentioned roll. Remember the bike can be fixed but the human element takes awhile. And we certainly aren't getting younger. Don't be a cowboy.
