Is it possible to bend the backrest a bit
If it's a detachable there is a post on here somewhere on how to drill and relocate the mounting bracket. Basically you drill a hole down a bit further on the bracket, angling the backrest back. The hole only moves about 3/8", but the angle difference was perfect. If I get time to find the post I'll link it here.
Well you need to know that once you force the rest to move, you will weaken the integrity of the rest itself. You can't bend it and not weaken it so be aware if you do of how much pressure you may ever put on it. Noname
I drilled a hole between the other two on the rear mount. It moved the backrest back about an inch or so, doesn't sound like a lot, but it is. It also lowered it slightly, maybe a 1/4", no big deal. Wife is very happy.
